Network Compatibility
Saskatchewan
I have an iPhone 11 and I am wondering if it will be compatible with the network after the 3G shutdown or if I will be able to keep using this iPhone 11 with Public mobile or do I need to switch to Koodo or Telus for coverage after the update
1 REPLY 1
hairbag1
@Saskatchewan
it'll be fine for talk as it is VoLTE recognized by Public Mobile, so the 3g shutdown won't affect your calling in or out.
Here's a link with info and scroll down to the compatabilty checker..
https://www.publicmobile.ca/en/get-help/articles/volte
