Network/Account/SIM
JD_Oh
I bought a Public Mobile SIM card from Telus today since I need to setup my phone ASAP.
I tried going through the process with the app, but it's trying to finalize the process by sending me a code to my new phone number, but it's not connected to the network, because the process is not finalized, because I can't finalize the process, because I need the code...
You get the idea.
Please help ASAP
15 REPLIES 15
@JD_Oh wrote:
Solved with Rodrigo
self solution removed
JD_Oh
Solved with Rodrigo
@JD_Oh  You in the maritimes I’m in Halifax and still got power but it’s flickered few times and the wind has certainly picked up . GO AWAY LEE !
JD_Oh
That's a nice thought, except when a HURRICANE is about to hit your door eh?
Janii
He was switching providers and I think he did but it was awhile ago and I don’t remember much but know it was messy situation and he got everything sorted out afterwards!
@JD_Oh
Did you put the new SIM in your phone and wait to verify the 2FA code with Roaming Data enabled?
@Janii
Did you friend ask for compensation for the lost service? 😉
@JD_Oh
Patience is key when dealing online with a CS_Agent.
Janii
Yes, what they said! It’ll take awhile for an agent to respond, it happened to my friend. If I remember… overall, it took about 5 to 6 days to get his issue resolved.  At this present moment, you’ll have to wait; I understand it’s frustrating but someone will speak to you soon.
@JD_Oh  There closed right now but maybe if you don’t get a reply by noon tomorrow give them a little nudge and ask what’s the next step
DDM69
Unfortunately it sometimes takes a while to get a reply.  Hopefully they are still available and get back to you soon.  Not sure if they work around the clock.
JD_Oh
I have not one, but 2 instances of tickets where:
    1. The agent greets me, says they will help me with the issue, they just need additional info
    2. I respond within 5 minutes of that message with the requested info
    3. Nothing.
    4. I reply "Hello?", "Anything else you need", etc
    5. Nothing.
Here's the kicker: It's the same agent.
What the heck do I do?
JD_Oh
No, there is no option to "Did not receive the code". It just keeps trying to send it to the phone which I can't activate.
Entering the wrong code 4 times just kicks me back, and restarts that impossible loop
will13am
@JD_Oh , support always verifies the legit account owner before interacting with a customer.  It is standard practice.  Are you able to use the did not receive code option to bring up the option of receiving the code via email?  I don't know it if is still possible, some customer used to say that entering the wrong code a few times will trigger the option to send code to email.
JD_Oh
Additionally, no one is helping me in Customer Service.
Started 2 conversations, and the agent never replied once after I provided all of the info he requested.
In both instances, asked for additional info, sounded all nice and helpful. Bam, never cared of my issues.
