Need to verify new phone number but code not sent
ColeFH
We are not getting the code to verify phone number. I'm thinking I should just cancel with public and go with a better company??
2 REPLIES 2
slusagm
your service is working ? you can make calls and data work?
you don't have to cancel, PM can help if you open a ticket.  Since you cannot properly login, you won't be able to open the preferred Chatbot ticket.  So, you will need to message them here:
TheSterlinger
@ColeFH
Is this new activation?  Did you keep the SIM card in the phone to receive the code?
If you are still not able to receive it  you can click on the link below to send a private message to cs agent for assistance.
