05-13-2024
07:31 PM
05-14-2024
07:47 AM
computergeek541
05-13-2024 08:05 PM - edited 05-13-2024 08:05 PM
To do this, @Louise7 , you activate with a temporary number, then ask the customer support staff to manually transfer the number from koodo prepaid to public mobile.
They need to do this as they share the same systems and typical porting cannot be done.
05-13-2024 08:05 PM
@Louise7 you need to get a new number first. After all setup, ask support to manual port the line for you
when you are ready, open ticket with PM support using Chatbot:
1. Open ticket via Chatbot (need access to My Account): At https://widget.telus.tiia.ai/publicmobile/publicmobile.html
Start by typing "Submit a ticket", then click "Contact Us", then "Other", then "Login" and finally click "Click here to submit a ticket ↗"
2. If you have trouble with Chatbot or you don't have access to My Account: Private message CS Agent at:
