Esim
Maddox1
Hi,
I purchased and Esim card and it didn’t say it was incompatible. Now once purchased it says it is. How do I now get a refund or order a SIM card?
2 REPLIES 2
@Maddox1 the error could be am error, support might be able to send you a QR code to install manually. Pleae private message CS Agent at:
HALIMACS
Incompatible with what ... your device?
Were you unaware your device was e-SIM compatible?
You can get a physical SIM card at a corporate Telus or Koodo location.
If you need to contact their support staff, here's how:
  1. Use the ticketing system for a faster response time. Click here to create a support ticket, then type Customer Support Agent, then Contact Us,  or,
  2. Send a private message to Customer Support Agent by clicking here.  You’ll need to be logged into your Community account for the link to work.
