06-28-2023
01:11 AM
06-28-2023
06:35 PM
computergeek541
@CS_Agent my phone deleted my e sim after getting everything activated being able to call out and send a couple test text messages to family members , it said it needed a restart after removal of old sim card. (Old bell card) I just need a new esim added to my phone so I can try out your service
06-28-2023 10:27 AM
@Th3FunGuy wrote:This doesn't make sense , just transfer all my information to a new acct. I'll clear the cache in my app make a new login and voila you just transfer my subscription as I put my services on hold as a lost phone. Then I'll load a new esim
@Th3FunGuy so, you are now on a new account but same phone number?
what exactly you meant by "you just transfer my subscription as I put my services on hold as a lost phone" ?
06-28-2023 10:27 AM - edited 06-28-2023 10:28 AM
@Th3FunGuy You will need a new account to get another eSIM from my understanding . As it’s only for new activations .But sure give it a try and let us know if it works . And we can advice others
06-28-2023 10:25 AM
06-28-2023 09:57 AM
this happened to me a couple weeks ago. Could not get a new eSIM from the support team unfortunately. It was very annoying. What I ended up doing is porting my number to another carrier that had eSIM capability and then porting it back to Public Mobile, and starting a whole new account with a whole new plan, which then gave me a new eSIM. I did not have time to wait for a physical Sim to come in the mail and stores I went to did not have Public Mobile Sim cards in stock.
06-28-2023 03:47 AM - edited 06-28-2023 03:48 AM
@Th3FunGuy as far as we know, there is a system limitations and PM support is unable to provide new eSIM if the installed one was deleted. You can message support to confirm, but likely you have to change to physical sim for now until they are able to provide new eSIM in such case. You can message support here
Once you got the sim, you can go to My Account, Profile page and make the update there
06-28-2023 02:09 AM
@Th3FunGuy You need to get a physical SIM card and swap the SIM card number . In profile tab of my account
SIM SWAPPING profile tabs
Note only do this on lap top or computer/ not mobile device
06-28-2023 01:32 AM
I was getting approximately 35mb download during lunch in the small town of Dryden, the only thing I didn't get was the ability to receive calls, but I was getting 4g and really fast loading. It was just an honest mistake and just need a new qr code sent to my email so I can add new Esim to my account
