10-10-2019 05:41 PM - edited 01-05-2022 07:30 AM
10-11-2019 04:06 PM
@cavemantoronto wrote:I missed it.
@cavemantoronto happens to the best of us!!!
@ChrisM7 anu updates?
10-10-2019 11:51 PM - edited 10-10-2019 11:52 PM
@srlawren wrote:
@cavemantoronto wrote:Has your mom changed phone recently? Has software been updated? Somtimes, updates have bugs in them. I would check APN and check data is turned on.
@cavemantoronto well, yes, this is a possible cause; however, @ChrisM7 indicated they don't see the data on the overview page. This means that it was all used up for his mother's current cycle.
I missed it. There could normally be an APN issue but that doesn't make account say no data left so there's no way to test for a setting issue. You're right. It's an account issue.
10-10-2019 06:09 PM
10-10-2019 06:01 PM
@ChrisM7 wrote:My mom plan has not have data for a very long time. Can a moderator check to see if my mom plan still has data included. I check to see if she does but I it doesnt show if she used it all up or anything.
10-10-2019 05:54 PM
it shows in the overview - My data & Add-ons section.
10-10-2019 05:49 PM
Ok thank you. I will wait until new cycle to see what happens. Appreciated
10-10-2019 05:47 PM
@ChrisM7 When you access your mom's selfserve account if there is available data then it will show up on the landing page. If nothing is there it means that the data has been all used up.
