12-10-2025 11:52 AM
My husband has a new phone and I am trying to reactivate it. His login won’t work.
12-11-2025 08:36 AM
Hello @ Kim47,
I sent you a private message. You can view it by accessing this link: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
12-10-2025 04:52 PM
@Kim47 wrote:Was able to login. But cant receive texts. Was able to get it via email however it will not let me purchase an eSim
Sorry for delay. At work right now so can't check immediately.
If you download the PM app on your husband phone and login into his account, you should be able to purchase an eSIM. Then the eSIM will be installed on your husband new phone. Which model phone is your husband using?
12-10-2025 03:49 PM
12-10-2025 02:22 PM
12-10-2025 02:14 PM
Does batch processing have to be on or off?
12-10-2025 02:05 PM
@Kim47 wrote:Where would a message pop up from the PM agent? Also, if I went on my account and downloaded an eSIM, would that work for his phone?
You should receive message in your private message inbox
Envelope icon on the right upper corner of website.
No, that will not work. If you download app and login into your account and purchase eSIM, your phone number and account will be set up on his phone.
To login into PM account, the user ID is always the email address (not phone number). If you enter the proper password, then PM should send your 2FA text to your cell number. Once you enter that 2FA text, then you will be able to access your account. If unable to receive 2FA text, you can sometime get 2FA email code instead.
12-10-2025 01:55 PM
12-10-2025 01:51 PM
Is there a way to login just using his cell phone number?
12-10-2025 01:48 PM
@Kim47 wrote:I think I am just going to go with another carrier. Nothing should be this difficult. So frustrating.
it can be frustrating for sure. FYI, your PM account need to be active to succesfully port your number to another company.
Using computer, you might want to try a different web browser, clear cache or incognito/privacy mode before trying to login. Website has caching issues.
12-10-2025 01:37 PM
12-10-2025 01:12 PM
Tried both. APP wont allow him to login. I had to create a new account to login on a computer
12-10-2025 01:08 PM
Sorry no phone number for PM customer service. All online.
I escalated a post earlier and CSA_PM did respond. Hopefully in the next little while. Might be busy.
BTW, what error are you guys getting when you try the login and password?
Have you tried to login via a computer?
12-10-2025 12:57 PM
Still no contact. Is there a phone number I can call?
12-10-2025 12:35 PM
I also reloaded the APP and now it says "Hang tight! Our APP is just catching its breath. Well e up and running shortly", but yet my APP is working no problem.
12-10-2025 12:15 PM
Thank you
12-10-2025 12:14 PM
I will try to escalate to CSA_PM. Should contact you via private message within 30 minutes.
12-10-2025 12:10 PM
We moved it over yesterday. He gets billed but his APP isnt recognizing his log in information
12-10-2025 12:05 PM - edited 12-10-2025 12:07 PM
Best to contact a CS_Agent by clicking on the Chat icon then type in “Submit a Ticket” then Contact or link to help with login to the account:
But did you read the solution posted on your previous post?
https://productioncommunity.publicmobile.ca/t5/Get-Support/I-m-trying-to-re-activate/td-p/1391073
12-10-2025 12:02 PM - edited 12-10-2025 12:03 PM
new phone? was your husband has PM service on the old phone?
if he does, you don't reactivate, you just need to move the sim card to the new phone
if he has physical sim , just move it over
if he has eSIM, he need to buy a new eSIM.
but you said his login does not work? ask PM to sort it out first, Since your account is locked, you will need support agent to help. Please send them a message
After PM helped with the login, then download the PM app on the new phone, login and to to Account -> Purchase Sim card -> eSIM to buy a new sim card
12-10-2025 12:01 PM
Im honestly gonna lose it right away. I need to speak to someone. AN ACTUAL PERSON. Im am trying to activate my husbands phone. He is already an account holder, it will not let me log in.
