01-28-2017 06:31 PM - edited 01-04-2022 01:27 PM
Thanks for any help in advance
TLC467
My Account
01-29-2017 05:19 PM
@TLC467 wrote:
Yes i am just switching phones
Thanks I will try this
@TLC467 as already mentioned, the L999 is a no-go with PM. What phone did you switch to, and is everything working fine now?
01-29-2017 12:06 AM - edited 01-29-2017 12:11 AM
@TLC467 wrote:
I've tried to set up my acess point names for my sim and it's not accepting it!! I have a LG P999 phone
TLC467
Sorry, but LG P999 is not at all compatible with Public Mobile. It will not connect to the network. The P999 was sold as Optimus 2x by Wind and Videotron and as the LG G2x by T-Mobile and is not able to connect to either of UMTS bands 2 or 5.
In any event, sorry but your phone isn't going to work. Even it were compatible, since you were saying that you can't connect to the network, please note that access point name settings have nothing to do with the actual connection to the network. Acess Points could be wrong or blank and you would still be able to register on the network, make/receive phone calls, or send/receive text messages.
01-28-2017 08:47 PM
01-28-2017 08:39 PM - edited 01-28-2017 08:44 PM
@TLC467 Our "go to" place to confirm compatibilty is http://willmyphonework.net. It reports your phone is NOT compatible with Public Mobile's network, so you need a different phone. Here's post to get you started: http://productioncommunity.publicmobile.ca/t5/Getting-Started/How-do-I-know-if-my-phone-will-work-on...
01-28-2017 07:43 PM - edited 01-28-2017 07:45 PM
Are you trying to edit an existing APN? Some phones don't allow you to edit built in APNs. Just create a new one with a different name. The name field is only for user reference and does not factor into the settings. Do the editing with the Public Mobile SIM card in the phone. Doing so will allow the phone to associate the APN to the SIM card.
01-28-2017 07:28 PM
Hey TLC467,
Make sure you're following the steps shown in the guide below to properly set up the Public Mobile APN on your phone.
Have you activated your Public Mobile SIM card before placing it in your phone?
01-28-2017 06:46 PM
01-28-2017 06:39 PM
Hi could you ne more specific on what it is not accepting? or exatly what is happening?
ie it wont save the new settings
settings save, but still no data
you maybe might rebooting phone\9 assuming that has been done), or possibly try clearing partition cache. |some phones might requre a factory reset (lg G5 i belive, so not sure about yours)
