Need help logging into account
rozjung
Help can't login into account to change credit card information!
Reset password doesn't work
hi @rozjung
did you try reset password and failed?
if you need CS agent's help, please submit ticket
at : https://publicmobile.ca/chatbot.
First type Forgot Login,
@rozjung
for logging in , First try to use the Reset Password link there on the login page (or direct link: https://myaccount.publicmobile.ca/en/forgot-password) enter any possible email addresses you could have used and see if it works
if not, PM support will be your friend then, please open ticket with them
1.  Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have problem with Chatbot: Private message CS Agent at:
Once you lgged into, go to Payment page, click Manage my plan and Update card information:
https://selfserve.publicmobile.ca/en/account/payment/manage-cardhttps://selfserve.publicmobile.ca/en/account/payment/manage-card
@rozjung  If you already reset  pass word and cannot log in get support to help you re gain access
  • Get support by starting a conversation with virtual Chat box /SIMon. Click here
  • you can send a private message   To CS_Agents by clicking here.
  Watch for reply top of page to the
   Right ( envelope image )
@rozjung
Have you ever created a My Account before? If not and you are a current customer (have been active within 90 days and have not ported out to another provider), you can submit a ticket here to: Create or forgot My Account email or password link
