Need another eSim
BobbiJo
@sfn
are you using the app?
go to Subscription & Add-on page, scroll down to the bottom and click Shop SIM Card Now
or post us screenshot of what you see
sfn
Do not see ESIM on Subscription & Add-on page, only roaming is available as an option.  How else can I order an ESIM?
@BobbiJo  You need to rebuy a eSIM from the app  go to subscription add on notice shop sim at bottom tap it and choose eSIM download and install it that’s it
@BobbiJo
are you trying to get a new eSIM for a new phone? or your deleted the old one and need one now?
Either way, you will need to rebuy a new one
To rebuy new eSIM, First, download the app on your new phone, click   or    at the bottom left to bring up the menu and go to Subscription & Add-on page, scroll down to the bottom and click Shop SIM Card Now.  You can buy and install eSIM from there
