Need an information from a recently closes account
Lalie
Hi ,
i need help to retreive my previous account, which has be Closed.
thanks,
Lalie
or to minimally retreive my previous bills, Or a proof I was a member for that period.
 @Lalie   Open ticket via private message as mentioned by @esjliv   PM Support can at least provide you with the previous bills
@Lalie wrote:
Hi, I really need to reactivate my old account, or to minimally retreive my previous bills, Or a proof I was a member for that period. Please, I think a little something can be done . Can I reach the account departmen?
thanks
thanks in advance
@Lalie  - you could check with a customer support agent and see what they can provide you.
Public Mobile Representatives customer support agents (CSA) can be contacted by either two methods, found here:
If you are no longer a current public mobile customer, you will need to use the 2nd option in the above link to private message CSA.
edit: if you were in nonpay/suspended status for over 90 days, or you ported your PM number to another provider, you will not be able to reinstate your old account/number, but you may be able to obtain records of past billing info. by requesting it with CSA.
@Lalie
Don’t think you can access your old account if your account is closed but doesn’t hurt to try and reach out to a CS_Agent but I doubt it.
Lalie
thanks
thanks in advance
MrSpock
@Lalie hi once you leave public your account is permanently closed sorry
