02-28-2024 01:03 AM
I ported my cell number to Public Mobile and it's been much longer than 5 hours and I can't send or receive texts. I can get calls but texts do not work. I tried all of the troubleshooting steps already; nothing is working. I also tried to click chatbot link to send a Mod a DM but that gives me a 404. I'm stuck with a chatbot that doesn't lead anywhere with solutions and I can't send a DM so hopefully someone here can help? 🙂
02-28-2024 10:00 AM
It works now.
02-28-2024 08:53 AM
Yes.
02-28-2024 01:16 AM
Try rebooting your phone or resetting your network settings. If still not working contact an agent.
During business hours, they strive to answer customer messages swiftly. You will often get an answer within an hour. During peak periods, you may need to wait up to 48 hours.Customer Support Agents are available:
Keep an eye on the envelope icon in top right hand corner for a reply from the agent
02-28-2024 01:15 AM
Yes; I followed all of the instructions as well as the troubleshooting. Still no texts. Calls come in but no texts come in or go out.
02-28-2024 01:13 AM
Did you say YES to your old provider to port out?
