Need PUK code
Rvbonzai
My sim is locked need my PUK code
slusagm
you sure it is the sim card pin you forgot and got locked?
Not sure if you can get the 2FA text and login for Chatbot ticket, I think it is easier to just message them using this link:
HI @Rvbonzai
if it is the sim card PUK you are looking for (and not the carrier unlock code), PM support staff can provide you that.
 submit a ticket with CS Agent using Chatbot here:
             Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can submit  ticket by direct message:
@Rvbonzai  No worries support can help
send  a  private message   To CS_Agent
