Need Mod Help! Failed CC Payment, Accounts now suspended!
stretchma60
How do i get in contact with a MOD to reactivate two accounts that were suspended following a failed Credit Card Autopay?  Bank says everything is fine on their end and we're now without service and obviously need our phones for work
Thanks
stretchma60
Yes, that's what i meant.
I just ended up using another card for now as we really needed the phones up and running again and will speak to the mods as to whats going on with the accounts.
Thanks
@stretchma60 wrote:
could not make a payment through *611 either
Assume you mean, your credit card on file was still not acceptable. So, you're down to waiting, or getting a voucher: https://productioncommunity.publicmobile.ca/t5/Announcements/Real-Time-Payment-Vouchers-are-here/m-p.... Use the voucher online or by phone. If the payment is enough for your current plan, service should restart. Wait a few minutes and you reboot your phone.
Not much solice for you, but autorenewal failure is rare.
stretchma60
@stretchma60 Yes, it is worth trying a different credit card or purchasing a voucher. But first try dialling *611 to see if you can make the payment.
stretchma60
Ive contacted the mods and no reply as of yet.  Ive also spoken to Visa and they've said everything is fine but when trying to re-activate the accounts, Visa says that they are no even receiving the signal to try and process the amount.
Would trying a different card speed up this process (Amex or Mastercard)??  or is the account suspended until a MOD looks at it?
Luddite
Send  a private message to the moderator team with your phone numbers and an explanation. Since you have two accounts include both account email addresses.
Meanwhile, if you need to make phone calls try an application like that from fongo.com. It provides free calling across Canada from wherever you are connected to wifi.
Given their backlog it may be a day before you have a response. Perhaps, turn on email notification of private messages so you see their response as soon as possible.
