Need Help for My Account
damontse
Hi,
I would need to register for online access so that I can do my payments
Timer
@damontse
you never Register To create a My Account profile, do you activated at store.
then create a My Account profile you’ll need the help of a Customer Support Agent. Chatbot
do you Remember: if you activated online you should have already created a My Account.
 then  Reset Password
@damontse   if you have activated online, you should have created a My Account login already
But if you activated in store, then yes, the account was not created yet.  But you can open ticket with PM Support and they can help
message to the CS Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
dust2dust
You can also do payments by buying vouchers and dialing 611 to enter them. Or go to some stores and use the real time payments option.
If you signed up in store then yes now you need the help of the support people to set up the login account.
