Mysterious calls in usage list
FdF
Why a I seeing so many calls to 1(902)580-4001 in my usage list?  I don’t know that number and never knowingly called it. Yet it’s showing up many many times in my usage history.
FdF
Yes. My question answered Thanks 🙂
hi @FdF there are more than one voicemail number.  But they should all end with 4001 or 4002 or 4003.  So, does the the number also ends with that?
FdF
Thanks for quick replies!!  There’s another mysterious number appearing, starts with (778). What would that number be for?
is there a way to suppress the display of these numbers in the usage history list?  They add a lot of clutter!
Yummy
This is your voice mail access number.
hi @FdF no mystery.  The number is Voicemail. The usage log will record calls gone to voicemail or when your check voicemail  So, all safe
