06-28-2023 02:53 PM - last edited on 06-28-2023 05:49 PM by computergeek541
My voice is not being heard (or is being distorted) during regular phone calls but during WhatsApp calls it is fine. Do I need a new SIM card? What is the issue?
06-28-2023 05:59 PM
@Lolo-Yoyo We happy you got it working 🙂
06-28-2023 05:59 PM
Good news. Keep in mind this should only be temporary. Seems somethings going on with LTE in your area. Maybe think about putting it back, say on Saturday.
06-28-2023 05:55 PM
I had tried all the rebooting options with no success.
06-28-2023 05:54 PM
THANK YOU. This seems to have resolved the issue. Thanks for walking me through the process!
06-28-2023 05:07 PM
Not usually the sim card. Either the phone or poor reception area. Reboot the phone try again. If you have access you could also try your sim in another phone to see what happens. I have issues with my cheap phone however my friends iphone has great reception with my same sim card. Just a few things to try
06-28-2023 04:33 PM
Okay, I'll try.
06-28-2023 04:30 PM
Thanks, I'll try this.
06-28-2023 04:29 PM
Your plan is only about speed. The suggestion was to change your network connection down to 3G or WCDMA or UMTS to see if the voice problem improves.
06-28-2023 04:28 PM - edited 06-28-2023 04:29 PM
@Lolo-Yoyo what kind of phone do you have?
There are two ways to deliver voice calls, 3G and LTE (4G)
Most of use still needs 3G for voice regradless the plan you have (ie, 4G and 5G plan could still be using 3G for voice )
But if you have a newer phone and on PM VoLTE compatible list, the you can use VoLTE (4G) for voice
So, question is what phone do you have? model and brand?
06-28-2023 04:28 PM
@Lolo-Yoyoin phone settings cellular >cellular data options >voice & data and select 3G see if it helps with voice calls
06-28-2023 04:25 PM
I have a 4G plan. I'm not sure what you mean?
06-28-2023 03:01 PM - edited 06-28-2023 04:28 PM
@Lolo-Yoyo Try your preferred network to 3G and see if that helps with voice
06-28-2023 02:59 PM
Thank you. No, it has been happening for a few weeks but it actually seems to be getting worse as of yesterday. My internet is working fine. I tried disconnecting from and reconnecting to wifi network already.
06-28-2023 02:56 PM
@Lolo-Yoyo Did it just start to happen ? If so good just be a local network problems check
Outage map in your area:
https://istheservicedowncanada.com/
you can always try resetting network settings to and see if the helps
