03-29-2022 12:50 PM - edited 03-29-2022 12:51 PM
I tried to help others writing a post including cost calculations but post is not here.
I do not use abusive words or profanity, just explanation and question about calculation.
I treed to post 3 similar post and all gone???
Community
03-31-2022 05:54 PM
@esjliv wrote:@BorisDoris disappearing posts could be under that unmoderated area of your profile, or they could also be under your DRAFTS section. Look under your avatar under your My Profile section under the bravos area.
Also, posts may be being removed due to be redundant, this can happen as well.
Thank you. Found in unmoderated area following link from @dust2dust .Strange?! No numbers, no bad words. Dumb filter or low IQ AI.
No in draft. I learn if oracles remove post there is a note in a post and sometimes reason.
Thanks everybody. This support better than AI or paid agent.
03-31-2022 07:08 AM
03-30-2022 01:46 AM
It was supplied to us by @oglat in this post when another member was experiencing the *poof* the magic dragon disappearing post bug. You can find it here....
03-29-2022 01:15 PM
@dust2dust wrote:Yummy: I copied it from a reply from Jb456 the other day. It's been mentioned around on occasion.
He, he, that is OK. I bookmarked it based on your post but would still like to know how people found that link.
03-29-2022 01:08 PM
03-29-2022 01:02 PM
@dust2dust wrote:Try this link to see if what you typed is there.
Interesting link! How did you find it? It seems I cannot get there going through Community site.
Even I found few of my posts there. Absolutely clueless why they have been removed.
03-29-2022 12:55 PM
I have found that it doesn't seem to like some numbers. Although it did keep the voicemail number I mentioned earlier.
