My phone vortex HD65 is not accepting sim card
Kyordey
Phil_Adelphus
@Kyordey   Do you mean the sim card size is wrong?  The Public Mobile sim card is 3 in 1, you just remove the outer spacer/s until you get to the right size.  If that's not it or what has already been asked perhaps you can elaborate so we can understand the problem better.
@EB0 wrote:
If you means, not connecting to public mobile network, it’s possible that your phone is locked or isn’t compatible with public mobile
The phone is not carrier locked and is band compatible.
EB0
@Kyordey , what do you mean by not accepting the SIM card?  Is the phone connecting to the network?  If not then I wonder if the account activation was successful.  Make sure to check that.  If it is a mobile data issue you are referring to, check the APN settings against this help article.
https://www.publicmobile.ca/en/on/get-help/articles/set-up-data-on-an-android-phone
Kyordey
What might be the problem.
It is a new phone
