My phone shows NO SIM
11-24-2021 01:13 PM - edited 01-04-2022 05:08 AM
My phone shows NO SIM, I can't use my phone for make or receive phone calls, nor use data. How can I have a new SIM CARD?
Phones
11-24-2021 08:39 PM
@jimzhang1107 wrote:My phone shows NO SIM, I can't use my phone for make or receive phone calls, nor use data. How can I have a new SIM CARD?
Did you complete the SIM card activation and choose a Public Mobile plan, either in store, or online found here: https://publicmobile.ca/en/bc/portal/activation
This would be the next step after you have the SIM card.
After activation, perform a Reset of the Network Settings with the Public Mobile SIM card in the unlocked device.
11-24-2021 07:25 PM
Try first some visual checking, try cleaning the sim from any liquid or dust. Or maybe phone is not compatible try talking to Simonbot.the robot here in the website.
You can purchase new sim in the website public mobile or amazon or nearby mobile retail store.
11-24-2021 02:25 PM
You can buy from PM online, Amazon or local store:
But first, try your SIM in another phone if you can to see if it works, or at least reinstall it. Since when did that happens? Did you just activate your account?
Buy online now at Public Mobile.....2 for $5. That is if you can wait for the mail.
11-24-2021 01:33 PM
@jimzhang1107 was it ever work on this phone?
pull the SIM out and re-seat the SIM.. maybe loose connection.
if still fail, you will need to check it on another phone and see if you got the same error message. It could be the SIM..could be the device (the SIM tray and contact component of the device)
11-24-2021 01:30 PM
@jimzhang1107 : Have a look at devicecheck.ca .
11-24-2021 01:24 PM
Have you ever been able to use this phone on PM network in the recent past ?
When did you buy this particular phone ?
What make of phone is it ?
11-24-2021 01:17 PM - edited 11-27-2021 08:47 AM
Edit: If the issue is caused by improper SIM provisioning, you'll need to contact CS for help:
https://widget.telus.tiia.ai/publicmobile/publicmobile.html (faster response time)
Type "ticket" > Click "Contact Us" > Select your issue > "Click here to submit a ticket↗"
or send a private message to:
and describe your issue. Include your name,phone #, account #, Email address,4-digit PIN to speed up authentication process.
After sending the message, watch your community inbox for their reply.
11-24-2021 01:16 PM - edited 11-24-2021 01:19 PM
What kind of your device ?
is it unlocked !!
no need to buy it new SIM card,
can you test your SIM card in another device to you know where the issue from SIM card network or device issue, maybe your device is locked to carrier..
