01-26-2019 08:58 AM - edited 01-05-2022 03:09 AM
Hi I just paid my phone bill and changed my plan to the talk,text,and 4g of data, with long distance, and nothing I can call out, I can't text, my data is not working, and it's been a good 5 hours since I renewed my account, what do I do
01-27-2019 09:02 PM
I would start by rebooting my phone. Then check your online account and see if the new plan you choose is there.
Cheers.
01-26-2019 03:12 PM
-*-*-*I recommend contacting the Moderator team which is actually Public Mobile support just click here to private message a Moderator - Just to set expectations it usually takes 24-48 hours for them to respond-*-*-*-
01-26-2019 12:41 PM
I suggest you sent PM the moderator team and tell them your issue. include your phone number, account number and PIN.
01-26-2019 09:11 AM - edited 01-26-2019 09:18 AM
here are more detials about the lost stolen trick. If that fals try t he $1 trick.
01-26-2019 09:06 AM
Ok I will try that thank you
01-26-2019 09:01 AM
