08-06-2025 08:19 AM
I just signed up yesterday, and my phone works, but when you call the number, it says " this number is not in service"
What can I do to rectify this?
08-06-2025 10:15 AM
Thank you for the escalation! The customer is already in contact with an agent.
08-06-2025 09:34 AM
Thank you for responding. I have implemented your suggestions, but I still receive the same message when you dial the number. If you stay on the line, it does connect after 2 sec.
08-06-2025 08:55 AM
hi @keithgreen
make sure you removed the old carrier sim card, or disable the old carrier esim
then reboot phone and Reset Network Settings.
if same, ask PM support to help.
you can submit ticket by direct message:
08-06-2025 08:27 AM
@keithgreen If physical SIM card try it in another phone or reboot the device can also try resetting network settings too see if that helps , if all else fails get support to investigate
you can use the orange chat bubble bottom right of screen or send a private message To CS_Agent
