My monthly rewards if I switch plans?
rayling
I currently have rewards on my monthly subscription and want to switch plans but don’t want to if I lose my rewards.  Can someone let me know?  Thanks
2 REPLIES 2
@rayling you will enjoy the same rewards on the same rewards system after the plan change.  No worry, make the  change and enjoy
And a reminder, you might want to use Change on Renewal instead of Change Now when making plan change. With Change Now, unused days and data on the old plan will be forfeited, no partial change
@rayling  You won’t loose old rewards for switching plans I can confirm I just switched to the 20GB for $39 and kept mine . Check it out
