09-25-2018 11:25 AM - edited 01-05-2022 05:46 AM
11-10-2018 04:43 PM
@Hardeep74 What plan did you have before changing? If no data on your previous plan, its apn issue, or network setting issue.
11-10-2018 03:12 PM
@Hardeep74 wrote:I recently changes my plan. First I only had the Ontario wide plan. Now I got the canada wide plan with 4.5gb data and canada wide calling. However, on the new plan everything works (texting works, I can call other provinces in Canada). But my internet/data will not work. Can you please assist?
You should make a new post. Anyway,
11-10-2018 02:44 PM
09-25-2018 12:00 PM - edited 09-25-2018 12:02 PM
@Mrdanambition wrote:Mon internet ne fonctionneent po
Si vous avez déjà consumé votre données, quand vous essayez d'accéder un page sur votre navigateur, le système vous redirecte au https://www.publicmobile.ca/en/on/zero-balance (ou le même page au français).
Si il n'est pas le cas, voir des causes suivantes...
If you have used your data, when you try to access a page on your browser, you'll be redirected to the zero balance page, English or French.
If that's not the case...
09-25-2018 11:37 AM - edited 09-25-2018 11:44 AM
What plan are you on? Do you have an active data plan?
Is there data left on your plan? Do you see your data add-on in self serve show?
When did your data stop working? Did your data always work untill then?
Do all of your other features work? SMS? MMS? Phone calls?
Without knowing more details (actually, without knowing ANY details)... can't offer much but can tell you the most common problems are needing to set your APN / not having data left / restarting your phone / phone data restriction enabled
