My data plan says I have 500mb and my data stopped working at around 250mb.
Daniel4
So my data plan is 500mb and 100 min of calling and unlimited texting(the 15$ plan). My data stopped at around 250mb. My data is turned on and it shows im using data but i cant do anything that needs internet. I got data usage notifications, but i thought it was a bug or something wrong cause my plan for sure has 500mb.
7 REPLIES 7
@Spike1, $15 does not come with 500 Mb of data.  There is also not an addon for 500 Mb of data available currently at Public Mobile to add.
The other posters are correct. The OP is mistaken in what their plan provides.
Spike1
If you do actually have 500mb and your data stopped early, you should check if you have data limits set on your phone.
chukdefatey
@hycm53 wrote:
Try power off phone for 30 seconds or more and then power on, if it does'nt work, try reset network setting.
You can also try the lost/stolen trick:
To report your phone stolen. Login to your account. Choose Plans and Add-on tab. Then choose Lost/Stolen Phone tab. Then choose Suspend Service tab. Logout. Wait few minutes. Login in and report your phone found. Restart your phone.
How would doing all this Help? The $15 Plan never ever had 500mb data. It was always 250MB if you have set up Auto Pay. So the Original Poster got exactly what he or she should have had.
The $15 plan IS 250mb. You got what you paid for. Nothing more. Nothing less. There are data add-ons available for purchase to tie you over to your next renewal.
Edit: ninja'd by LovesToPM. 🙂
kelvarnsen
How much data does your account say you used? What tells you you only used 250, your account or your phone?
LovesToPM
The data that comes with the $15 plan is 250 MB.
If you need more data, you can buy Data Add-On or switch to the $25 plan.
hycm53
