10-10-2025 01:25 AM
Simply put, I have 1.29 of 24 GB used as of this cycle starting today. I don't watch videos or anything with data, usually just E-Mail and stuff so I'm not sure where even the current data use came from - but either way, copied directly from my page...
For the current cycle, of that 1.29 GB, 1.19 GB is my one-time data bonus, and 0.10 GB is from my plan. Why would my data bonus be getting used up before my plan itself? The whole point I get the bonus for is for AFTER my plan is used up...not before!
Subscription Usage
Refresh
10-10-2025 09:18 PM
Thank you - it all makes sense now!
10-10-2025 09:25 AM
if you don't click Usage breakdown and just look at the Usage Odometer, then yes, it will show 1.2GB on day 1 of the cycle, but the total data would also be 24GB rather than your monthly data 20GB, ie, 1.2/24 GB
just remember to click Usage Breakdown to see the actual usage without the bonus addon
10-10-2025 09:10 AM
Oh, so EVERY MONTH will start with a 1.2 GB usage for me as it were?
10-10-2025 02:48 AM
The bonus data is one time and doesn't ever reset, so if you've used up some of it in a past cycle it will continue to show that usage until it's fully used up. You must have gone over your plan's included data at some point in the past.
