04-04-2020 02:27 PM - edited 01-05-2022 10:14 AM
I found my data has not worked anymore,it still works yesterday, but the signal bar is full and changed to 4G+(it used to be 3G),all the settings I haven't changed and I'v check the all settings is correct, I'v reboot and take out and in my SIM card several times, I am
really appreciated whom can help me!
Joining Public
04-04-2020 02:40 PM - edited 04-04-2020 02:40 PM
@senbabala It seems that some phones got an update overnight. Please check to see if you data is enabled. Thanks.
04-04-2020 02:37 PM
@senbabala Maybe you used it all up? Check the data counter on your selfserve page. If it's not there then you have used it all up.
PM is currently running a promo on their 1 GB data add-on you might want to take advantage of.
04-04-2020 02:36 PM - edited 04-04-2020 02:41 PM
PM uses Bell and Telus towers which are 4G but speeds get throttled to 3G. Did you check your self serve account under data and add,-ons if no amount of data is showing then you have used up your data. You can buy an add-on for 1GB for $15.
04-04-2020 02:35 PM
@senbabala wrote:I found my data has not working anymore,it still works yesterday, but the signal bar is full and changed to 4G+(it used to be 3G),all the settings I haven't changed and I'v check the all settings is correct, I'v reboot and take out and in my SIM card several times, I am
@senbabala Maybe try the lost/stolen trick, log into your account, select plans/add-ons tab, then phone lost, suspend service and log out. Wait 5 mins, log back in and resume service, log out and reboot the phone.
04-04-2020 02:31 PM
04-04-2020 02:28 PM - edited 04-04-2020 02:35 PM
Is your cell data switched to on in the settings.
Could you be out of data? Check self service.
Check your apn settings:
