rewards
01-05-2020 11:06 AM - edited 01-05-2022 10:14 AM
good day, how do i go about getting $1 off a month, buy referring someone
01-07-2020 12:20 AM
and family is a great place to start!
01-06-2020 08:03 AM
@spank1979 Giving the referral code is the easy part. Convincing a friend to leave their current provider can be hard. People are surprisingly loyal to their high priced plans. More importantly you have to make sure they are the right fit for public mobile. That they understand the online service model and if they are unsure you take the extra step of helping them get started and navigate the community til they get the hang of things. That makes for a happier customer who will stay longer and pay out more rewards for you in the end.
01-05-2020 05:22 PM
You provide the referral code and when they join, your referral uses your code. As long as they are a Public Mobile customer, you get your $1 off per month. And don't forget to do the auto pay and get your $2 off per month.
01-05-2020 12:12 PM
You can give your referral code, which can be found upper right after logging in with self serve, to anyone you like. They will need to enter it when activating to get a 10.00 reward. You will receive 1.00 monthly for every month they are active with PM. There is no limit to how many referrals you provide to others.
01-05-2020 11:18 AM - edited 01-05-2020 11:18 AM
How does it work?
It’s simple: you will earn $1 every 30 days for each friend you refer to Public Mobile who enters your unique referral code in the referral code box during activation. Plus, your friend will receive a one-time credit of $10. You’ll continue to earn Rewards on plan renewal dates as long as your friends remain active customers.
01-05-2020 11:13 AM
ok thanks man
01-05-2020 11:07 AM - edited 01-05-2020 11:09 AM
When they activate their account, they should use your referal reference number. You'll provide the friend referal code to them. Log into My Account and you can find it there..top right sde of page.
