Activate my phone
04-04-2020 03:03 PM - edited 01-05-2022 10:14 AM
04-04-2020 03:20 PM - edited 04-04-2020 03:21 PM
@Yellowcello Sounds like you are trying to activate your account and are having problems adding your credit card for Auto-Pay.
- Enter the credit card address exactly as it appears on your statement. (Including case)
- When entering the postal code do not enter any spaces. If that doesn't work then include the space and leave out the last digit.
- Do not use the unit number field even if you live in an apartment or condo and use a desktop browser if you can.
Hope this helps!
04-04-2020 03:05 PM
@Yellowcello Have you activated your PM SIM and created your online account? Here is a thread to get started: https://www.publicmobile.ca/get-started
Also more details would be appreciated.
04-04-2020 03:05 PM - edited 04-04-2020 03:06 PM
@Yellowcello here are 2 articles on activation. They basically explain it all:
1. What you require to activate https://www.publicmobile.ca/en/bc/get-help/articles/what-you-need-to-activate
2.How to activate https://www.publicmobile.ca/en/bc/get-help/articles/activation-account-set-up
04-04-2020 03:04 PM - edited 04-04-2020 03:05 PM
Could we get a bit more information so we can assist you.
What seems to be the problem?
Is your phone locked?
