02-04-2018 01:34 PM - edited 01-04-2022 03:27 PM
I have switched it on and it still does not connect to any network so I would like to know how to fix this problem please I need my data.
02-05-2018 12:01 AM
@Anonymouswrote:You will need to send a private message to the @CS_Agent, giving them your phone number and 4 digit PIN, Account email address.
Detailed explanation of specific your issue .
them can help you a lot nice team service
good luck
Once again S--S, no need to bold and increase the text in your post. It seems like you are yelling at us
02-04-2018
01:47 PM
02-05-2018
12:00 AM
NDesai
good luck
02-04-2018 01:47 PM
Are you able to receive/make out going phone call?
If so, follow the setting apn instruction.
02-04-2018 01:47 PM
Hi @Sandermonkeyson. Is this a new activation on Public mobile? If so, are you sure that your phone is compatible with the PM network? You can check it by going to: https://willmyphonework.net/ and entering your phone information & carrier Public Mobile, and it should tell you if it's compatible.
After that, you should check if the APN settings might need to be adjusted. For information regarding APN settings, please see the following knowledge base article.https://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Setting-up-Data-APN-on-your-phone/ta-p...
If that's not your issue, please provide further details.
