01-23-2025 06:32 PM
Hi Community - anyone have an estimate as to how much data a 50-minute zoom call would use please? Don't wan to be cut off mid call!
01-23-2025 07:53 PM
My thanks!
01-23-2025 07:19 PM
You probably right
01-23-2025 07:17 PM
@Johnny876 wrote:My Brother I believe if you have for example 50gb of data and you are are having that 50- minute zoom call if say it would run you about 5-10gb of data due to the fact it's 5G and the speed is higher but not only that when I was streaming music I used 1gb in less than 10mins .. it depends typically on how much you're going to make zoom calls and how long you spend but typically 5gb - 10gb I was streaming TV shows on Netflix and it typically used a lot of bandwidth as well as data.
That's a tad much their @Johnny876
01-23-2025 07:15 PM
01-23-2025 06:36 PM - edited 01-23-2025 06:37 PM
