03-25-2024 01:24 PM
I found my bonus data added on March 13 to my account is now missing. It should not expire until 150 days later and I didn’t cosume it at all. I tried to submit a ticket but the page is not loading. Can any agent please look into this for me.
03-25-2024 02:02 PM
Thanks for the tips here!
03-25-2024 01:32 PM
did you change plans ?
Clipped from Help Files...
Will I lose my special bonus data if I switch plans?
The bonus data will remain active unless your account becomes inactive, you switch to a plan of lower value or to an incompatible plan.
03-25-2024 01:28 PM
HI @Bell14
i think possible, CS agent usually are ok with that. Check with them
please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
03-25-2024 01:26 PM
Will I be able to get the bonus back if I upgrade my plan again?
