My account
Oliveshy
It's been a month and I cannot access my account to make a payment. I thought when I set up account in December I had put auto payment but now when I go to login it say not valid username or password.
@Oliveshy
Auto pay can fail
To make payment and reactivate plan .. if you know PIN number you can *611 with a voucher and *611  no PIN needed . You can also do this by by calling 18554PUBLIC . otherwise log into self serve make manual payment and reactivate service and or update credit card if necessary
My account
Legend  and features
Change plan / update cc /auto pay
Account #/ change # port /swap SIM
If you  still have service and your plan renews today / tomorrow you can ignore this suspended notice
@Oliveshy   what exact error message you got?
Some people have trouble logging in with "Page Expired" error just because of browser saved password, not PM issue
Some people got error with Dark Theme extension on Chrome and got weird long errors
Some people got error because they already have a Telus My Account login and then the browser saved password got mixed up
You tried reset the password?
Try to use the Reset Password link there on the login page (or direct link: https://myaccount.publicmobile.ca/en/forgot-password) enter any possible email addresses you could have used and see if it works
if not, PM support will be your friend then, please open ticket with them
1.  Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have problem with Chatbot: Private message CS Agent at:
dust2dust
What recording do you hear when you dial 611?
HALIMACS
@Oliveshy
Try using the forgot password function to the most likely e-mail address you used.
Then check the e-mail account to see if you get a forgot password link.
EDIT:   I presume you are without some / all services ?   Also try calling 611 to hear account status to be sure of what it is.  (much like @dust2dust  offered below...)
