05-05-2022 02:46 PM
05-05-2022 08:55 PM
05-05-2022 04:06 PM
@Madisonoregan - if you activated instore it is possible you have not created a self serve account yet.
If so, you can register for one here: https://selfserve.publicmobile.ca/self-registration/
05-05-2022 03:33 PM
Do you have several email addresses that you would have access too? You can open them and search public mobile to narrow down which one you used and then used the forgot my password link
05-05-2022 02:49 PM
HI @Madisonoregan You can try to use Forgot password and enter email address you have
but if you really cannot remember which email you used, just open a ticket with CS Agent:
at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
Once ticket is submitted, make sure to check your Community Inbox(top right corner envelope icon) periodically for response from PM's CS Agent
