06-30-2023 10:31 AM
Can't access My account. When I try to submit a ticket a error appears. It indicates go to overview page. Then a page appears that looks like my account page but the data does not appear. Clicking on My profile tab results in
Internal Server Error appears under Account info and under My Phone Number
Does anyone have any suggestions to get out of this loop?
My Account
06-30-2023 12:43 PM
Thank you all sorted . I was able to connect to @CS_Agent with your assistance.
06-30-2023 10:35 AM
@geologue- Have you tried restarting your browser in privacy/incognito mode.
06-30-2023 10:35 AM - last edited a month ago
geologue
Please open ticket with PM support:
Start by typing "Submit a ticket", then click "Contact Us", then "Other", then "Log In", finally click "Click here to submit a ticket ↗"
(if you cannot receive 2FA via SMS, click "Didn't Receive code" or "Resend Code" and choose "Send email" to get 2FA)
2. If you have trouble with Chatbot or you don't have access to My Account: Private message CS Agent at:
PM just changed to a new EverSafe login system and you need to complete the setup on this new system.
Have you login to My Account since EverSafe was introduced?
If you have already created an EverSafe id, you can ask the code to send to email instead
On the screen it is expecting you to enter the code, click Didn't get the code? or Resend code and then choose Send email
If you have not created an EverSafe id yet, you won't be able complete the part to link your My Account with the EverSafe ID, that needs a working phone with a working PM sim using SMS. (Sending the code to email would not be a choice until EverSafe id is fully setup)
Try these workarounds, it could bypass the SMS in linking My Account with EverSafe ID
- Reset your password to self service account. Once reset, sign in again with new password. Might be able to receive 2FA via email instead to gain access.
(!!!You will need to click Resend Code and then Send email to trigger the 2FA to email) - Potential workaround (for some): If you don't have access to SMS OTP, try entering an incorrect OTP code 4 times. For some individuals, this is giving the option of an email instead.
If none of those workarounds helps, please open ticket with PM support:
Start by typing "Submit a ticket", then click "Contact Us", then "Other", then "Login" and finally click "Click here to submit a ticket ↗"
