09-24-2022 09:25 AM
Hi,
My Rewards were not applied on my last bill. My MC was charged(automatic payments) full amount($15+Tx) without my rewards applied.($2+$1+$1).
Thank you,
Flori
09-24-2022 05:22 PM - edited 09-24-2022 05:27 PM
Well then that's hardly the solution of the question 🙂
Can you provide images of your payment history here for the last few renewals. Did you possibly use the lost/stolen function before your last renewal?
Adding - by the way, to anyone interested, interesting on the all posts view that the little green checkmark at the far right is gone. It was there recently.
09-24-2022 05:08 PM
Hi, I login in to Payments and find My Upcoming Bill showing the rewards as should be. My last bill(September 2022) does not applied my regular monthly rewards.
Thank you for help.
09-24-2022 03:17 PM
open ticket with PM support and ask them to check it for you
At https://publicmobile.ca/chatbot.
Start by typing "Submit a ticket", then click "Contact Us", Then click "Other", then click "Click here to submit a ticket
have trouble with Chatbot: Private message CS_Agent
09-24-2022 11:11 AM - edited 09-24-2022 11:12 AM
@Blackbearwhite chexk your Payment History and compare how PM charged you this time and last time
Login to My Accounts and confirm if you see all your eligible rewards and confirm if they are showing in $ value
update: sorry, typed slow.. already said above...
09-24-2022 11:08 AM
If you login to your account and get in to the Payments screen and find My Upcoming Bill , do you see the rewards area and dollar amounts?
09-24-2022 10:56 AM
No changes I did.
09-24-2022 10:56 AM
I think so. I did not make any changes.
09-24-2022 10:55 AM
No, I did not make any changes to the plan or rewards.
09-24-2022 10:50 AM
Might you have opted in to the new points system?
09-24-2022 10:14 AM
Loyalty, autopay and referrals should be applied on every bill unless you did any changes to your plan. Community rewards might miss one month depending on timing.
09-24-2022 09:32 AM
@Blackbearwhite Hi have you recently made an early plan change ? If you have you would pay full amount this cycle
