My Region Setting
MurfeeMe
Good Afternoon
Im wondering why when I set the My Region Setting to PEI where I’m located it always reverts back to Quebec or BC or anywhere but the right place
thanks
19 REPLIES 19
@MurfeeMe wrote:
On the Public Mobile main page it says
your region is set to ? Whatever pick a Province
I’m in PEI with a 902 area code and IPhone 12 and when I change it to PEI on the PM page it always reverts back to some other province
I’m sure it’s not life or death but it’s one of those pain in the rear things
@MurfeeMe  Ah yes, this does this to me as well. I kept trying to keep it to my province but it kept switching on me occasionally.
Yeah, I don't think it really matters what province your PM page is set to really.
Although Quebec used to be advertised with slightly different prices. But looking at that now, they seem the same as other provinces.
@CountyDownIeUk wrote:
I had a time issue on iPhone SE. Switched from LTE to 3G and viola....fixed.
When it comes to cellular network network type, that doesn't have an effect on this website's settings.
Wouldn't a violin do better with the frequencies? 🤣
The regional setting is based on browser cache and not IP, i think.  I am able to change my region all the time and it stays without issue.
did you try another browser as well??
MurfeeMe
Switch is off in my Safari settings
MurfeeMe
Nope in Safari my block cookies switch isn't on
@MurfeeMe
Maybe your cookies are not set, or you're using private/incognito mode.
@MurfeeMe
Other than the occasional region specific promotion or plan (usually only Quebec will get these) the region the pm website is set to makes no difference. Mine usually reverts to Ontario for some reason despite being in bc.
 @MurfeeMe : There was a Quebec-only promo a while ago that was in English so it would seem that region may mean something. Or I have it wrong. It was a while ago.
@MurfeeMe
if you change to any Region you like to chosse is nothing will be change at webiste public mobile.. everything is the same..
only for the Language English or French..
 @MurfeeMe : Great update. Everybody was guessing. Are you allowing cookies for this site?
MurfeeMe
My phone is set to Atlantic Time and it’s never been touched
MurfeeMe
@MurfeeMe
Use your iPhone, iPad, or iPod touch to change your region
  1. Open the Settings app.
  2. Tap your name, then tap Media & Purchases.
  3. Tap View Account. ...
  4. Tap Country/Region.
  5. Tap Change Country or Region.
  6. Tap your new country or region, then review the Terms & Conditions.
Change your Apple ID country or region - Apple Support (CA)
How to change region on Android
  1. Open the Play Store app.
  2. Select the icon at the top left corner (options button) and select Account.
  3. Click "Country and profiles" or "Language and Region" option.
  4. Once you set up your new country, your payment method would also be refreshed.
Change your region in Windows
  • Select Start > Settings > Time & Language > Region.
  • Under Country or region, select your new region.
  • You can switch back to your original region at any time.
Change your country or region,
@MurfeeMe you meant the clock region?
what brand and model ode of  your phone?  You have selected use System time?  try to toggle that and see if makes any difference
dabr
@MurfeeMe wrote:
Good Afternoon
thanks
@MurfeeMe   Are you asking about the Community page region?  That happens occasionally to me and it's nothing to really worry about as it doesn't affect anything.  Try clearing cache/cookies and use incognito/privacy mode or a another browser to see if it helps.
CountyDownIeUk
What kind of device are you talking about?
HALIMACS
@MurfeeMe
Is your phone number a 902 area code, or something different?
Public Mobile tends to operate out of the EST for most things
