My PUK code
Matthew_young
Hi I accidentally locked me out of calling and messaging by locking my PUK and have no idea how to get it back my if you need my phone number respond to this pls do this asap
8 REPLIES 8
@Matthew_young
let's try to get your PUK code first
if you cannot open a ticket with Chatbot with your account validation problem, please message PM support directly:
Matthew_young
Not a solution is still a problem I hit the wrong button
Matthew_young
As said above it won’t let me unlock the SIM PIN option for my iphone
Matthew_young
When ever i try to get a ticket it makes me input my community name and password and my password don’t work
Matthew_young
I do have an iPhone but I cannot turn off my SIN PIN
@BKNS27 wrote:
@Matthew_young
If it is an iPhone, go to Settings>Cellular>SIM PIN and disable the SIM PIN you locked the SIM.
To disable a SIM PIN, most devices require the customer to enter the PIN, which the customer wouldnt have.  Also, when a phone is asking for for the PUK< the needs to be entered first before the PIN would even be accepted.
@Matthew_young   you are talking about SIM puk code and not device's screen unlock PIN, right?
for sim unlock PUK, you will need to submit ticket with CS agent and they can help
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
@Matthew_young
