My Data is not working
Andres2
Hi. My account shows that I have 3 GB of add on data and yet, I’m not able to use it at all. I have consumed my regular data plan and was hoping to use the add ons, can you help me? Thank you very much.
@CS_Agent
1 REPLY 1
@Andres2
just in case there is a browser cache issue and you are reading old info, please login My Account again using Incognito mode and confirm the add-on
Also, try to reboot the device once
and are you on Android?  if so, make sure you disable the data limiter "Set Data limit"
