Help
07-10-2023 01:22 PM
07-10-2023 02:15 PM
HI @Rekha data/text/voice all not working?
is your phone connected to PM network?
call 1-855-4PUBLIC and check what the system says about your account/number
07-10-2023 01:49 PM
Confirm your account is still active. If you had autopay set up and it failed then your account is suspended.
Check you account first before we proceed.
Try using different browser. Try Incognito/private mode. Clear browser’s cache. Try forced refresh. Use computer and not phone to log in.
07-10-2023 01:40 PM - edited 07-10-2023 01:40 PM
Is your account is Active? Login to your account and check. Or dial 611 and check if your account is suspended or active.
Also check to see if there are any outages in your area but it shouldn’t be that long:
07-10-2023 01:24 PM
Did you check if your account status is active? To avoid browser cache confusing, please login My account using Incognito mode to confirm account status
If it shows On Hold (Suspended) , then it is a payment issue. Click "Pay Now and Resume Services" to make a manual payment
If it shows active,
- first try to reboot the phone
- If that does not work, change the Preferred network type or network mode to 3G only or WCDMA only and see if it works
- Try to click Reset All Networks and see if it helps
- and do you have another phone to test the PM sim ? just to make sure it is not a device problem. Also, that can force a sim card re-provision and it could resolve the problem
- Also, try the phone in another area if possible, it could be just a local network outage
- if nothing works, PM supports are your friend, message them:**Monitor your Community inbox (envelope icon on top right) after the ticket is opened. CS Agent will reply to you there
