07-14-2022 03:40 PM
07-14-2022 04:16 PM
@rothca9 Where are you? Manitoba perhaps.
07-14-2022 03:45 PM - edited 07-14-2022 03:45 PM
@rothca9 It is a reception issue. Try changing network type to 3G
Select Settings.
Select Mobile Data.
Select Mobile Data Options.
Select Voice & Data.
To enable 3G, select 3G.
07-14-2022 03:43 PM
I can make outgoing calls and some calls still come through but most don’t. I have an iPhone 8+
07-14-2022 03:42 PM
HI @rothca9 You cannot receive calls?
can you make calls out?
Try changing type to 3G Only
Also tell us what make, model of your phone
