My Account
Melvs
Password changed successfully in MY Profile, but can't log in
Hi @Melvs   if what suggested above all fail, maybe submit a ticket with Cs agent and they can help
at : https://publicmobile.ca/chatbot.
First type Forgot Login,
NDesai
@Melvs If you still can't login, try changing your password again. This time click on the 👁️ icon to make sure you typed your password correctly. Also, try to add a new password that you have't used on PM before. Sometimes the system doesn't let you use the same password for security reasons.
@Melvs
Try again using Incognito mode or try on another browser
Also, if you have any dark theme extension on the browser, disable it
and if you are using saved password , please try to not use it for now, just manually type in the new password
