Blackview Oscal C80 Compatibility
gaoran
@gaoran
You need at least 2 frequencies in 3G and 4G to work properly on PM.
This phone only have one frequency B7 (2600).
Return for it for a refund.
@gaoran
these are the bands on your phone BOLD are compatible bands
3G bands HSDPA 900 / 2100
4G bands 1, 3, 7,  8, 20, 40
But these are what needed on PM, you need as many compatible bands as possible.
And your phone is not compatibility with PM network
dust2dust
gsmarena suggests that the phone is not compatible with here. Maybe 1 matching LTE in case of volte. Send it back.
Adding - also according to the manufacturer. If you like the brand then some models seem fine - A53 Pro and A100 are probably the best of them for here. Others may be a little light on LTE like A80 Plus, A80s
