06-18-2017 12:41 PM - edited 01-04-2022 01:54 PM
I know this has been covered before, but I just wanted to double check.
If a buy the US voice/text/data package, and I run out of data before the 10 days are up, can I add just the US data package to my account? So I would have two US packages overlapping at the same time.
Thanks.
06-18-2017 01:16 PM - edited 06-18-2017 01:17 PM
re-read it not sure if he is purchasing talk text and data at first so not sure.
@will13am, he is purchasing the full US addon so all 3 and this question was if he used up his data so as @imm1304 says he could purchase just the data addon but not the whole talk text data again until the plan has expired.
06-18-2017 01:16 PM - edited 06-18-2017 01:20 PM
@will13am, as I understood it, the scenario is that the OP wishes to buy a different add-on before 10 days are up. First add-on is the package (talk+text+data). So anything other than this package add-on is allowed by default.
Same goes for those who have purchased one US raoming data add-on. If they use it up before 10 days are up, they can purchase a different data add-on.. just not the same one. This isn't convenient or ideal and I suggested that the restriction be modified or lifted in Public Lab here.
06-18-2017 01:07 PM
The question is about buying add-on when data is used up but time has not expired. I thought the time has to expire first before purchasing the same add-on.
06-18-2017 12:48 PM
Hey @RogerI,
Yes, you will be able to buy just the data add-on. Basically, the system won't let you purchase the same add-on again until 10 days are up.
