09-23-2021 09:43 AM - edited 01-06-2022 03:26 AM
Hi,
I changed my plan from $40 to $50 for the month of September. In my bank account, I see I was deducted for both the amounts on 20th September.
Could you please let me know how I can get a refund of one of it ?
Thanks
09-23-2021 01:03 PM
sign in to Self-Serve, to review your account, if you found at Available Funds: $ ? has the amount left,
leave it for next bill cycle the will take it from there automatically,
or Explain your issue to Contact Customer Support Agent by CS_Agent ,
they can solve your issue, they are nice service Team the will help you 100%.
Here’s How To Contact Customer Support Agent by CS_Agent, and Submit a Ticket
Good Luck
09-23-2021 10:49 AM
If funds are on your PM account, I suggest you leave them there as they will be used for the next renewal.
I hope you did change plan selecting 'change at next renewal' as it will be painless transition from old to new.
In very particular circumstance when your plan renews at the same day when you decide to change your plan, you might be charged for both plans - old renewal and start of new.
You could argue your case with CSR to get refund but changing plan 'immediately' forfeit all minutes/data from old plan with no reimbursement.
09-23-2021 10:23 AM - edited 09-23-2021 11:12 AM
@anitaper2011 wrote:Hi,
Thanks
If you change to a new plan immediately while the current plan has not run out, you won't get a refund for the current plan even if the current plan is just one-day old.
That's the official take. You can always argue your case with a CSA, maybe you'll get lucky and catch one in a good mood. 🙂
09-23-2021 10:07 AM
What does your available funds show? $40? If there are available funds, you can use it for next month. Which plan are you on right now?
09-23-2021 10:01 AM
@anitaper2011 When did you request the Plan change? Did you request around Sept 20? and which option did you pick? did you pick "Change Plan now" or "Change plan in the next renewal"?
09-23-2021 09:58 AM
Did you do an immediate plan change or did you future date your plan change.
The first one will charge you for the plan immediatly and cancel your current plan. The second will take effect on plan renewal date
