12-02-2021 08:57 PM - edited 01-04-2022 05:03 AM
I bought a Samsung S10. It's on the compatible list.
I migrated the working SIM to the new phone, adjusting it from Micro to Nano
The phone is not connecting to the network.
I've rebooted, reset the SIM card, reset the network, tried cleaning the SIM card with an eraser, toggled airplane mode, etc. I did get a notification it had found the SIM card but thats it.
I tried Simon but that went in circles. When I tried to then open a ticket, the login wasn't accepted even though it works fine otherwise.
Suggestions?
12-02-2021 10:36 PM
@DavidFB wrote:I bought a Samsung S10. It's on the compatible list.
Suggestions?
@DavidFB - if this is a 2nd hand phone, check to see if it is unlocked.
Contact the previous provider(owner) to unlock it for you. You will need your imei number, dial *#06# to get it.
Maybe also check if your phone is blacklisted here: https://www.devicecheck.ca/check-status-device-canada/
12-02-2021 08:59 PM
you can try to test your SIM card in another device to you know the issue from SIM card network or your device issue.
you need to Contact Customer Support Agent by CS_Agent, and Explain your issue to
them can solve your issue, they are nice Service Team they will help you 100%.
Here’s How To Contact Customer Support Agent by CS_Agent,
Good Luck...
12-02-2021 09:01 PM
do you try to do backup and Factory Reset,
12-02-2021 09:09 PM
Thanks! Have sent a message.
It's appreciated.
12-02-2021 09:09 PM
Suggestions?
Where did you buy the S10? was it a CPO from from PM?
do you have another active SIM from another provider? try to use it and see if it works.
and if you put your sim back to another phone, it works? just want to make sure you didn't scratch the SIM and broke it by any chance.
12-02-2021 09:12 PM
12-02-2021 09:37 PM
You'll be in good hands talking with a CS Agent, especially for an account-related issue. In the meantime, some things you can try to troubleshoot the issue:
Try another SIM card in your Samsung S10 to see if it's an issue with the phone.
Also, are you able to try your Public Mobile SIM card in another phone? If it works, then your SIM card is okay. If not, it's possible that the SIM card "chip" got damaged in the process of removing/replacing or resizing it - a new SIM card would be required.
12-02-2021 09:55 PM
I plan to buy another SIM retail tomorrow in case the old one is flaky in some way.
The PM SIM was working fine in the old phone.
Perhaps I should try moving it back to see if its still OK. The SIM works fine in the old phone.
12-02-2021 10:00 PM
@DavidFB wrote:I plan to buy another SIM retail tomorrow in case the old one is flaky in some way.
Try to move it back and see.
If you are going to buy a new SIM tomorrow, have the Mobile guy to use an Active PM/Telus/Koodo SIM to test your new phone as well.
(some places don't sell SIM without activation.. call ahead and check...)
12-02-2021 10:06 PM
i suggest you to get a New SIM card is better for you and fast way
from any Retail store or gas station near you and you buy it right away,
Where To Buy A SIM card,
You can purchase a Public Mobile SIM card at a variety of retail locations. Click Here link
to open our store locator and find the closest retailer to you.
or
Too easy buy it online or in store visit Here link, or Pickup 1-2 Hours.
How To Change Your SIM Card,
the SIM change functionality has been re-enabled in My Account, now with an additional security step: 2 factor authentication to further protect against SIM card fraud.In order to change the SIM card associated with your account, you must now verify your request through a one-time security code that will be sent via SMS or email.To change your SIM card, please follow the below steps:
Please note: after 5 failed attempts to verify your security code, your account will be locked, and you will need to have your account unlocked and your SIM card manually updated by an agent by submitting a ticket link here..
