02-23-2022 12:11 PM
I have a newer samsung phone and I want to move my existing Public Mobile sim to this new phone and keep my existing phone number. How do I do that? My existing phone is a samsung phone.
Phones
02-23-2022 10:21 PM
Thank you
02-23-2022 10:20 PM
Thank you!!!
02-23-2022 05:49 PM
Thanks @Anonymous I thought you were laughing at my old SIM picture 🙂
thanks for the answer
02-23-2022 01:04 PM
@hTideGnow : ?? More recent what? I was referring to answering your question about old SIM's. Pre 2015 were bought as a single size. And if you changed phones with a different size you had to make arrangements to either find a frame or scissor-cut the smaller out of the larger or buy another of the right size.
After that they became tri-punch.
02-23-2022 01:00 PM
@Anonymous wrote:@hTideGnow : Looks like summer 2015.
HI @Anonymous .. LoL.. one thing I learned is that this place moves slow, the My Account is like Summer 2014..
Ok, will try to get a more recent one. 🙂
02-23-2022 12:42 PM
Depending on which model of Samsung phone you have but most newer ones are nano SIM size so take the SIM from your old phone and place in new phone if the size is the same. If not, you need to add or remove a spacer to fit the SIM tray.
02-23-2022 12:38 PM
02-23-2022 12:23 PM - edited 02-23-2022 12:23 PM
HI @Crouch As said above, pretty much just "Plug and Play" with the SIM
If you find your current SIM too make, see if it is pre-cut and you can take it off to transform in to nano:
Curious, are all PM SIM are tre-cut? even from the old days? anyone see an PM SIM that are just one size ? cannot
02-23-2022 12:20 PM
Nothing special to do and nothing to do with your PM account. Everything is 'plug and play'.
Turn off old phone; make sure new phone is off too.
Remove SIM from old phone
Plug in SIM into new phone
Turn on new phone. Confirm everything works as expected: SMS/call/Internet.
Enjoy new phone.
02-23-2022 12:16 PM
Just move the SIM over. Size matters. Going down is easy. Going up needs the original frame parts. But they may very well be the same size.
02-23-2022 12:16 PM
@Crouch You don't need to do much. All the account info is on the SIM card. So, all you need to do is to pull the SIM from your old phone and move it to your new phone.
