3 hours ago
- last edited
2 hours ago
computergeek541
Hi All!
*****Attached below are my phone plan details in screenshots*****
My predicament summary is this:
My Current Subscription Cycle is May 03, 2024 - Aug 01, 2024
I move Aug 26th to London, UK.
I want to keep my phone number while gone 1 to 2yrs & pay as little as possible to do that. I want to pay as little as possible for the period of Aug 1st-Aug 26th too & want to know if I can use up all my rewards without a plan or need the cheapest 30 day plan? is there a pay as you go plan option?
That seems an ideal fix for this because I will have a UK plan while over there..
Details/questions:
1. For Aug 1-26 I want to pay as little as possible. Happy to burn through my rewards with the cheapest plan, or, (if possible) without a plan? For example can I simply cancel the renewal for August 1st, & 'float by' on rewards until I leave in August 26th, then keep my phone number until I come back?
2. I want to keep my current phone number so when I come back one or two years from now, I still have the same number. How do I do this while spending as little as possible? Is there a way to not have a monthly plan but just 'float by' on my public rewards? Of course, my understanding is I will have a uk sim card & phone plan, but my understanding of what to do for keeping my Canadian number is fuzzy at best.
I have screenshots of all my rewards & whatnot. I will include them for details.
Cheers to anyone who can help with either question
2 hours ago - last edited 2 hours ago
Do you need this number for 2FA while you are abroad?
Since PM doesn't support service outside of Canada and the US, you should line up a reliable alternative before leaving.
Be aware that the VoIP options mentioned above can be hit-or-miss for getting 2FA texts.
Oh, and to clarify, PM is not a pay-as-you-go provider. You will need an active plan to use any of your add-ons. If possible, I'd schedule a change at next renewal to the lowest cost plan available. Check web based account portal as well as the app - there might be different offers between the two.
3 hours ago
@turkeyscanfly, after reading @softech's suggestion I would go with the $15 fongo option for sure, it will end up being a lot cheaper than going to TELUS for $100 a year plus you won't need to worry about renewing if you are there for longer than a year making it over $200
3 hours ago
since you don't have too many friend rewards, there is really no need to keep your account with PM
Check those service that you can part of your number for a small fess, like numberbarn or those services
3 hours ago
@turkeyscanfly, Since you're going to be away for 1 to 2 years and wanting to keep your number I think your best option would be to move over to TELUS Mobility (who happens to own PM) and go on their $100/365 day plan
If you try to stay with PM that's an option too but you'll need to unsubscribe from your and very important that you remember to renew before 90 days is up otherwise your plan will close and you will lose your number, so renewing a few days before you hit the 90 days is recommended. I think it would be easier to just port out to TELUS though as you only have to renew once or twice depending on how long you stay in the UK.
3 hours ago - last edited 2 hours ago
if you are moving to UK for 1 to 2 years, you need to pay at least $20 every 85 days, so, it is about $100 per year to keep the number
A better way is to port the number to Fongo, which has a $15 port in fees. And Fongo is VoIP phone, so it is FREE after you ported in. Then when you are back in Canada, you can port the number back to a proper mobile provider, which is free to port out by then
For the part that you are not leaving until April 26, go to My Account and pick a plan that suit your needs for the 26 days
But if you decide to keep it with PM, here are what to do:
PM only allows the account to be suspended for 90 days or your account will be permanently closed, and you will loss the number.
So, your option is temporarily suspending the account and reactivate for 30 days before the 90 days deadline.
Here is what you can do:
