08-31-2017 12:16 PM - edited 01-05-2022 02:47 AM
Hello there,
Hope that you are doing well.
I want to change the phone. But my old has the big old SIM. The new phone has the micro or nano SIM. I ordered for a new SIM, but don't know how to activate this new SIM keeping my existing phone number. Kindly help.
Mashkura
09-04-2017 08:09 AM
09-02-2017 10:15 PM
@ RodgerB Please refresh the page and restart the phone. It takes a bit if time.
09-02-2017 07:12 PM
I have done this with my new sim, but nothing is happening...Help
09-02-2017 01:20 PM
@merekore glad we could help. Cheers!
09-02-2017 01:14 AM
It worked! Thanks 🙂
09-01-2017 01:49 PM
@merekore you sign into your self-serve account, click the Plans and Add-ons tab, then click the Change Sim Card sub-tab. Enter in the new SIM card number, and click Submit. Done.
09-01-2017 12:27 AM
08-31-2017 02:08 PM
@merekore When did you join Public Mobile? Look closely at the SIM you already have; you may be able to push out to size you need.
Otherwise, see if there is a WOW Mobile kiosk near you and go there to pick up a new SIM.
08-31-2017 01:58 PM
08-31-2017 01:24 PM
What @stonechucker said....
I made the same phone move and just had to punch out the nano sim from the micro sim, and voila!
08-31-2017 01:23 PM
08-31-2017 01:09 PM
Just to confirm, your current card is the old fully solid SIM?
Newer cards are the triple punch, which are all 3 sizes at once.
08-31-2017 01:05 PM - edited 08-31-2017 01:05 PM
08-31-2017 12:53 PM
Log into the self-serve site: https://selfserve.publicmobile.ca/
Click "Plan and Add-ons" at the top, then click "Change Sim Card". You'll be prompted for the new SIM number, enter that and click "Submit". 🙂
Any problems, contact a moderator via private message and make sure to include your phone #, email address and the new SIM # along with a brief description of the problem (only include that info in a PRIVATE MESSAGE, never publically).
